Water pump 86'
Water pump 86'
Question: I have a 86 coupe. put away a few weeks ago (live in Michigan) had a warmer day so got her out to stretch her legs, of course when I got back, noticed a leak. Coming from water pump.
Looks like time to change.
1.) I hear it is a PITA to change, looks like a lot to remove? any tips or thoughts
2.) since I am taking all this stuff off, what would you suggest I look into changing while im there? I have heard things like timing chain, etc.
Car runs great, has 160,000 on OD, but I would like to do some preventative stuff while i have it torn down.
Thanks Guys
Thanks Guys
I would do the belts, t-stat, and rad cap as preventative and to ensure good cooling system health. If the hoses are soft and spongy or hard and crinkly replace them too. Nice new hose clamps. That's as far as I would go. Flushing the system while it's apart is easy enough too with a hose and good pressure in and out of the block and radiator get all the old sediment out of there. If not no biggie (that can be messy).
The main problem is that the AC compressor bracket attaches on top of the water pump so it has be be removed to get the water pump off.
I did a thread on a timing chain replacement, so it might have some helpful hints since it talks about removing the AC compressor:
http://forums.corvetteforum.com/c4-t...placement.html
Take photos of everything. To get to the WP you have to remove a lot of stuff. Which means you have to put back a lot of stuff. Bag and tag everything. The ac compressor will be the hardest. There is a torx bolt hidden on the bottom. I forget the size, sorry. When you do get it off take it with you when you go to get a new one. I ended up getting one off eBay. AC Delco NOS. Fit perfectly. Good luck.
