Climate Control doesn't work...repair or replace?
Climate control on my '88 will turn on and light up but it doesn't blow any air/heat and the temp numbers go hay wire on the display. Does this sound like a repair or should I replace the entire unit. Also, would replacing the unit allow air/heat to blow or is there possible some sort of internal motor that's gone bad. Any help would be great...thanks.
You can probably do the same with yours. As shown by this thread -
https://www.corvetteforum.com/forums...n-1988-c4.html
On my '96 which has a different unit than yours, I had problems with it. I took it out and cleaned the connectors with spray electronics cleaner and the contacts inside with a pencil eraser (followed up with the spray cleaner). Now it works fine (for nearly three years).
Or I could be completely wrong. Happened at least once before.
