Car runs exactly the same with MAF
unplugged, runs and starts good but for giggles decided to run with the MAF unplugged . Was surprised no difference,running , starting etc.
Do I need it
Do I need it
Did you just idle it or take it for a run? I'd be curious. I disconnected my MAP sensor and the car almost died. I can't see why you wouldn't need it unless the car is in limp home mode.
St. Jude Donor '17
What year is this on? I will also be curious to know how gas mileage may be affected. Don't need a scanner to get codes for older C4s at least, just a jumper and a note pad for the codes.
MAF is not used in cold start or until engine warms up and goes into closed loop. The computer has a matrix loaded into it to run the engine in open loop.
Pro Mechanic
Pro Mechanic
Newer cars use both a MAP and a MAF, so they have two ways to measure air consumption. Earlier cars don't; they are either/or. Only one way to measure air flow.
If the MAF is bad/not connected the ECM will use the TPS to guess what the air flow is.
I was troubleshooting a miss on my car and came home from work and started troubleshooting again. I found that the MAF was disconnected and I had not noticed any difference in the way it ran. I drove it to work and back, so there was a combination of surface streets and freeway driving. The miss turned out to be a bad plug wire, in case anyone is wondering...
Cliff when you plugged yours back in did you notice any difference?Just so people kknow when I took it out for a test run it never went above 150 degrees so I don/t know if it will be affected the warmer I run.My maf is a bosch.
Car is not going into closed loop without a maf sensor hooked up. You would be lucky to get 10 mpg ...If you hook up to a scanner you will probably see air/fuel readings way off spec without a maf...I wouldn't run the car without a maf sensor ,you need to hook to a scanner to see what's going on..Just because the car seems to run fine without a maf, doesn't mean it's safe to do so.....Running with unknown A/F ratios can cause engine damage..To answer your original question, if these cars didn't need a maf sensor , they wouldn't have one......WW
Not true. The parameters for closed loop mode on my car are:
Coolant temperature > 40.7°C = 104.4°F
Engine run time > 300 seconds (cold) if startup coolant temperature < 58.5°F
Engine run time > 206 seconds (warm) if startup coolant temperature > 58.5°F and < 158.5°F
Engine run time > 50 seconds (hot) if startup coolant temperature > 158.5°F
Oxygen sensor reading between 0.195 and 0.686 volts for > 10 seconds
There's no "MAF present and working" in there. As I said earlier, the ECM uses the TPS to guess what the air flow rate is. That statement is based on examining the program code in my ECM. I'm still working on that. You can contribute your expertise by going to my ECM web page and helping me out:
http://home.earthlink.net/~cliff_har...5/BUA/BUA.html
Pro Mechanic
Motor runs poorly w/no MAF because as stated above, ECM tries to estimate air flow off TPS and RPM which is a rough estimate.
In limp mode the ECM uses the resistor networks in the MEMCAL to determine injector pulse width. The microcontroller is held in RESET mode and does nothing. Everything is controlled by the FMD (Fuel Management Device) IC.
I believe the ECM also switches out of bypass mode and the ignition module manages the ignition advance curve, but I don't know for sure if this is true or not.
