Do you know what this is???
gen 1, 2, and bbc firing order.
I wonder if rice burners think the 1324 on my license plate is the firing order...
Now how about 18726543?
Prepare to get asked many many times what it means , because 99% of the people won't have a clue....I would of been one of them......WW
I must be losing my memory but it seems like after adjusting the points thru the door on the distributor and staring at the firing order on the intake manifold so many times 45 plus years ago, wasn't it 18236574?
That is probably the first thing I memorized when I got my first Chevy. Of course there is a variation used by cam manufacturers that claim more horses can be had by using a cam with 18736542. 4 & 7 are swapped. I have never tried one of those cams.
I can remember that, but I can never seem to remember the LS firing order for the C5's or later. (18726543 I had to look it up.)
Nice shirt.
Here is something useless I wish I could forget IDDQD, but I cant seem to forget it.
I found a site that has a shirt that looks the same, but they want 10 reserved before they will sell any.
If you look at the order of firing on the block instead of the different numbering systems , and start with number eight cylinder on the Chevy instead of #One, the order of firing follows the same pattern of order as a small block Ford 260-302. So if your a Ford guy and don't know the firing order of a Chevy, just pretend it's a Ford and the firing order still works. Later when they came out with the 351W they changed the firing order to keep cylinders 1 and 5 from firing in sequence so as to take the torque load off the front main bearing. Learned that from a Ford engineer when I worked at Automotive Research years ago.
