1993 Resonator vs x pipe (video)
For me it is hard to get a real sound from a video clip, but from what I can hear I like the X pipe better.
To me it sounds like the resonator has more of an individual puff for each cylinder, where the x pipe is smoother with a lower rumble/roar.
You have heard them both in person. Which do you like and how would you describe the differences?
Edit:
I forgot to say that I like the X pipe one better too.
Edit:
X pipe for not just sound but performance.
A 2 into 1, back to 2 is NOT dual exhaust. It is no different what so ever than a single muffler that has two tail pipes on the outlet. It looks good sure, but dual? Hell no it isn't.
X pipe for sure.
Side question, what are you filming with a GoPro? If so, is there a special setup you use? When I mount mine to the back I cant get a clean sound like your video.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I'd go with the one that creates none or less drone.
It is a gopro, I used the waterproof case with the open back piece. If you get the frame it should work as well.
