Carbon Fiber Hood Arrived
#103
I have a few problems to work out still. The body shop gave the car back to me but it still needs a little work.
1) Passenger headlight is not adjusted correctly.
2) The hood support isn't working.
3) Driver hood pin doesn't line up correctly.
4) The center stainless panel was dented by the throttlebody.
5) The wipers don't clear the hood.
The headlight shouldn't be a big deal. The hood support appears to have been damaged by the chroming process... looks great but doesn't work. I ordered a new one and waiting on back order. Not sure what to do about the wipers yet.
I attempted to adjust the hood pin myself, just a few bolts, but now the hood is jammed shut... will try and put some time in on it tonight.
#104
Ah yes, the price we pay for pioneering or doing something a little different from the norm. Aggravating as hell sometimes...problems that no one else has had to deal with or has never dealt with. I know the feeling well...the end result is worth it though!
Stay positive and keep at it...you are so close now!
These are all very minor issues, easy to correct, but it is all the time it has taken thus far to get to this point that makes them seemingly worse. After a minor adjustment, everything should be just fine.
Your body shop should be able to adjust the hood for a little more clearance on the wipers. I don't know the proper name of that part, but it is some sort of spring thing with a pointed acorn nut looking thing on the end, one on each side of the hood towards the windshield. These drop into the latching holes/mechanism in the body to latch the hood when closed.
Depending on how far in or out you turn it (with a big screwdriver), the hood will latch closer or farther away from the body. This up/down adjustment will in turn raise or lower the leading edge of the hood away from the top of the wiperblade.
I know this because I did it on mine a couple times since one side has a habit of loosening itself and changing my hood/panel gap on that side.
Hang in there...you are almost there!
#105
I also dont know what wiper blades you have but you might want to take one of yours to the auto store and compare it with the others to see if a different brand has a shorter blade. If there is a shorter one that fits it will be much easier to change the blades than adjust the hood.
#108
#110
Looks good. I think the end of the hood, at the cowl, in the center, would look better if it was like the rest of the edge. This would also probably resolve the wiper issue.
#111
I've had the car back for a couple weeks now. It has a list of issues, but my body shop guy is frustrated with it and wanted a break.
Current issues:
1) The paint is still off, it's closer but not right.
2) The headlights, hood, and front bumper aren't matching up properly.
3) The hood release is sticky because it's not lining up with the receiver correctly.
4) The double sided tape on the stainless panel is insufficient to hold them.
5) The hood support mounting location is no good.
#1, #2, and #3 will have to wait for the body shop guy. I've had a lot of frustrations with him so despite having to spend more money, I may go somewhere else.
#4 isn't a big deal, will just get better tape
#5 I'm having a local fabricator make a bracket. Basically the hood support needs to be adjacent to the wheel well or it will hit the alternator bracket when the hood closes. However, there's nothing to bolt to in the proper location because that's where the vent is.
Fabricator should have a price for me today. 1/4 in aluminum should be strong enough, but I'm concerned with the leverage on the fiberglass. There's a metal mounting plate I added behind the fiberglass to bolt to, but it may not be enough. Will just have to wait and see.
Bracket
Current issues:
Bracket
#112
I had to relocate my hood prop rod as well. I just welded a piece of flat bar to the stock piece so it moved it over and gave me clearance. Of course you have yours chromed already but it was an easy fix.
#113
Since it's small and mostly flat I may try polishing it myself rather than sending it out.
Sadly, whenever I get a procharger all this will have to be re-engineered again.
#114
Yeah, I want to try and make it look as good as possible. The fabrication place came back with a quote of $115. It'll take them 7 days or so, so hopefully I'll have it by next weekend.
#115
So, are these still being made? Are the current pieces being offered for rework or price reduction now that we all know the amount of finishing involved? 5k for a hood on a 5k car? Also can it be made lighter?
#117
Former Vendor
#119
The reason I ask is my procharger p600b has an annoying squeal to it that is partially muffled by a closed hood (p600b is an older noisier model but still produces great boost so I'm in no hurry to change it).
The squeal is most prevalent at idle. Once on the road, it blends into the road noise somewhat but is still there if you listen to it.
The newer prochargers claim they are quieter but I can still hear some parts of the annoying squeal in their newer line as well.
