1994 New acrylic targa top installation and alignment
I just bought a new Acrylic targa top from Melrose tops and I am rather reluctant to do the install myself due to some concerns I heard about relative to improper alignment could cause it to crack. Has anyone done an install and alignment on one of these and how difficult was it to align and do you have any suggestions.
Thanks a bunch
Thanks a bunch
I've done it. Not hard at all when you know what to do. Used to have Melrose, but now have OEM.
The alignment is for getting the brackets on the new TOP to be bolted down in the correct place so it's aligned with the brackets in the car.
The other thing is you can adjust how far the top presses into the A and B pillar weatherstripping.
Top alignment
Thanks very much!
Thank you very much for your feedback. I've never even taken the top off and I've got the instruction that Melrose sent with the top so once I take the top off I should have a better understanding of how the adjustment mechanics work. When you adjusted yours did you take the upper trim panel and the rear view mirror off like the instructions say to do? That's really the part I'm not looking forward to.
Thanks very much!
Thanks very much!
Targa top alignment
I changed my top yesterday and aligned the new one and everything went really good except I am not pleased with the position on the front windshield gasket. It doesn't seem to go far enough forward to sit right on the gasket. When you did yours did you have to do a forward adjustment which according to the instructions in order to adjust the top forward or backwards you have to remove the seat belt harness and the rear headliner trim panel and add or remove shims. I drove it after I changed the top and there wasn't any wind noise coming from that gasket area so I just assumed it was ok.
I noticed when I put a Melrose top on, that in the middle of the top it sat real close to the windshield trim almost touching it. The OEM top has a bigger gap there. Also noticed the front lip on the Melrose top digs further down into the weatherstripping. As with the OEM top put on after the Melrose, the front lip in the middle half of the OEM doesn't touch the weatherstripping as there is an impression left into the weatherstripping from the Melrose front lip sitting further downward than OEM.
You can adjust the forward/reward by adding/removing shims in the back. But I never hear of anyone doing that.
If there is no wind noise and no leaks. Then I wouldn't mess with it.
Again thanks so much for your advice!
