SLP cold air induction
If you are referring to the "Claw" it has been on my 94 for many years. Be sure to use their spacers on the stock screws and that they are not pulling out of the plastic tops or you could puncture your a/c condenser.
Pro Mechanic
Also be aware that the SLP "CAI" is does in no way, draw "cold air" in a C4. In fact, there is literally no benefit to it at all, other than psychological ones (you spent money, put in a part, and THINK your car is better now). For the price of the SLP CLAW, you could buy a cam, or a plethora of other parts, that would actually make your car faster.
OP, I didn't notice a power gain, very easy to install.
Navigator
if looking for performance mods you need to list a few things... trans, rear gear, stock?, and do you wrench yourself.
If you have an auto with the 2.59 rear gear changing that to a 3.07 or more will really wake it up and not set you back to much.
Look under the center console lid to see if the options from the factory is still there. get the codes and then do a serach for them... there is a post somewher here listing what they are.
Navigator
with a 6 speed you probably have a 3.45 rear gear. Just a heads up if and when you do long tube headers that exhaust is going to get a big drone issue. Whit my 94 the Borla was the first thing I did. Then when I modded the car and added LT's and 3 inch to the mufflers the drone was so bad I removed the Borla mufflers and put the stock ones on. Sounded kick *** but I could not handle the drone.
"The cold-air package and flow booster added 8.3 hp and 9.8 lb-ft at the tires on the otherwise-unmodified Vette. The entire setup is contained within the factory bodywork, so there's no cutting involved and no risk of water ingestion."
http://www.superchevy.com/how-to/vem...k/viewall.html
"The cold-air package and flow booster added 8.3 hp and 9.8 lb-ft at the tires on the otherwise unmodified Vette. The entire setup is contained within the factory bodywork, so there's no cutting involved and no risk of water ingestion."
The misplaced data figures and the word-smithing is so badly edited as to make the reader wonder if the dang thing is written in code or something!
So... posting LT4 numbers as result of rockers, an air foil, and the "Claw", sans porting - on the heals of THAT article... Let the buyer beware!
No reflection on you, B&B, but that article is pathetic!
http://www.ws6.com/mod-4.htm
I have a claw on mine. I cut an opening in the shroud to allow 'cold air' to reach the filters. The car ended up with a crisper throttle response, cooler temps and better top end. Gave me a consistent 1.5 mph bump in the quarter with similar weather conditions. I didn't test it without the hole in the shroud, so maybe that made up for most of the gain. But in stock form, it is not a cold air system.
Pro Mechanic
That means no real changes in head or tail winds, DA or changes in track condition. Whether I was at Capital or Bud's creek, I was averaging 1.5 mph more in the quarter with the claw and cut-out in the radiator shroud. Every time out.
BnB: "Truth is where you find it!" BUT! According to weight/ET vs. HP calculations, the "Claw" would have to be good for about 14 HP in the quarter for a 1.5 mph increase (over 300 base hp vs. 314 hp) on a 3250# car; boosting it from a 104.9 mph vs. a 106.4 mph.*
*± approx 1 mph either side of the average, depending on other factors.
14 HP would be a pretty significant adder for a bolt-on air thingy, IF it is true. Locobob's results (on a LT5) was less that 2 hp over stock. Hmmm..... A long way from 14. So! Just sayin...
I agree that the "'claw" and an air foil are poor bang for the buck. You may not even notice a difference when using them.
However, the claw is a good low restriction air filter and there is some evidence of less pressure drop through it than stock. There is also some evidence of improved flow with an air foil. The documented hp gains are so small as to be within the margin of error in testing.
Are they worth it from a performance standpoint? No unless you get them really cheap. They probably help some, but not much.
Seems like many on this forum are all talk and no action. Use the dyno for tuning purposes. Then take it to the track and get the real skinny. With any intake system that utilizes forced/cold air, the #s won't be realized until the car is in motion. Just ask those who use a Vararam. 10-12hp on a dyno but pick up over 2mph at the track.
Truth is where I find it? Consistent track data is where I found it. Where is your track data?
