loss spark
Old 03-03-2015, 12:42 PM
rcowher
3rd Gear
rcowher's Avatar
Default loss spark
Hi, I have a 1994 LT1 and i replaced the battery and now i have no spark, car just cranks and won't start. did i burned up something?
Old 03-03-2015, 01:15 PM
Jud Chapin
Support Corvetteforum!
Jud Chapin's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Do you know for sure you have no spark? How's the fuel level?
Old 03-03-2015, 01:23 PM
rcowher
3rd Gear
rcowher's Avatar
Default loss spark
fuel level is good, i pulled the plug wire off and can't get any sprark to the plugs. the car only has 49.000 miles and its been running fine before . it's been sitting for a while nad the battery was dead so i put i new one in and now it won't start
Old 03-03-2015, 01:28 PM
Jud Chapin
Jud Chapin's Avatar
It could have something to do with the security system. Have a look:
http://www.smokinvette.com/corvettef...ad.php?t=43242
Old 03-03-2015, 01:35 PM
Jud Chapin
Jud Chapin's Avatar
If the above thread doesn't help, you probably should post this in the C$ tech section.
Old 03-03-2015, 02:08 PM
rcowher
3rd Gear
rcowher's Avatar
how do I check the security system out
Old 03-03-2015, 03:07 PM
Jud Chapin
Jud Chapin's Avatar
If the car has the original alarm, read the owners manual. Did you read the thread I provided?
Old 03-06-2015, 07:40 AM
LannyL81
LannyL81's Avatar
If the starter engages and turns the engine, the factory security system is fine.
Check fuses.
Perhaps somehow the ignition control module got fried, although not likely. Some chain auto parts store can test them. Too expensive to just replace as they are not returnable.
To loss spark
Quick Reply: loss spark
