C4 Wheel Spacers
C4 Wheel Spacers
I was planning on throwing on some wheel spacers on my 93. But before I do so, what would be some good wheel spacers and a good size? I was thinking 1" spacers all around. Also, would I need to do any fabrication to the hub screws in order for the spacers to fit flush? I want to be able to flush my wheels along the fenders. But I don't want to do any other modifications to anything.
Ray
Ray
Are you installing different wheels? "Adapters" are used when there is a difference in wheel offset based on OEM and aftermarket wheels. A one inch adapter is equal to about 25mm. Adapters typically bolt to the hub and the wheel then bolts to studs that are part of the adapter.
A "spacer" is simply a disc that slides over the OEM wheel studs. That effectively reduces the number of threads for the lug nut to engage and tighten
One thing to be careful of is moving the front wheels further outward and winding up with tire/frame/wheelwell interference at full steering lock.
Below are the adapters I want and also what I plan on achieving:
Make sure you follow the wheel lug nut torque requirements and don't over tighten the lug nuts for the wheels. Don't use an air or electric impact wrench here! 90-95 ft-lbs will work fine.
Torque the bolts for the adapters per the install instructions.
Need4Sneed (02-23-2024)
Spacer or adapter.... well an adapter "adapts" it has different bolt patterns on each side.
A spacer is a spacer, if it's a thick enough spacer it will have it's own studs for the wheel side. But still a spacer will have the same bolt pattern on each side. I wouldn't call it an adapter if it doesn't adapt.
Now look at your goals. You posted a picture of a car with nice fat tires even with the wheel well. Looks great. Is yours going to look like that? NO.
You're going to take a more narrow tire and push it out to the fender lip. It's not going to look nearly as good.
My point is you can't just ask someone on a forum what you need and order it. You really need to take the wheels off one side of the car and put them where you want them, see if it looks like you want it to look like. If it does measure for spacers.
But I'll stick to my opinion, skinny wheels pushed out to the fender lip aren't going to look the same as fat wheels that have to be at the fender lip.
1 inch spacer is around 25mm or 25.4mm
factory offsets on sawblades are 54mm i believe or somewhere around there
so youll end up with a final wheel offset around 30
it wont fit at all and it will look ridiculous.
9.5 +45 on the front is flush
11 +50 rear is poking slightly 1/8 in depending on the tire, otherwise itsessentially flush with a 'proper' tire.
Tire size makes a huge difference as well as ride height
I had no problem with the studs on my Z-R1 style wheels and I do not think the 1 inch spacers look ridiculous on my car.
Is there a certain bolt pattern on the adapter that would be ideal for a stock C4 wheel??
I like it! That is something I am aiming for! I feel like my wheels are just a tad too into the fender and would like to widen them up a bit. It's not like I'm changing out my whole suspension lol you know what I mean? Just a little push is all I need. This isnt that serious of a project!
OR maybe even 1" and 1 1/4"
The bolt circle is 5 X 4 3/4 or 5 X 120.65, you want an "adapter styled" spacer that is both hub and wheel centric. You're looking for 70.3mm which is a quite common GM spec.
