94 c4 corvette backfire issue
This is my first time on any forum so bare with me..
I have a 94 vette with the lt1 and I am having an issue with bogging down real bad when I give it gas and then it will backfire.
I changed the starter as it was terrible.. I changed the air filter, plugs, wires and I cleaned the mass air flow sensor. Other things I've done include a new battery and fuel filter. I am at a loss as to what could be causing the problem. I hope it's not the opti but I think that might be the next thing I have to throw at it. What are your thoughts?
For the best resolution to isolate your issues; you will need the Factory Service Manual, and retrieve any stored troublecodes stored.
Since I was under it I pulled the knock sensors to give it a good flushing and replaced them could not bring myself to put back 20+ old parts
The car has 97,000 miles on it and the fuel filter was changed less then 1,000 miles ago. There are no codes. I've been trying to get it to throw one. It is doing exactly what antfarmer2 is saying his did, I will deff try the O2 sensors. Where exactly are they located?
Mine had 98000
Great to many times you never hear back if it's fixed but I did do my knock sensors at the same time the only way to get a good flush and one side was plugged up bad
One more thing while waiting for your sensors to arrive, have you checked fuel pressure? Have you checked to see if the diaphragm on the fuel pressure regulator is leaking? Finally have you inspected and cleaned the EGR valve? You can do all these checks for free, and it might lead to resolution of your problem.
If you follow the exhaust down from the manifold, you will see the sensors ahead of the cats. The first thing that will go through your mind is "how in the crap am I going to get to them". If you put your car on ramps and attack it from the bottom, access is not that bad. You will still need a u-joint socket to get to them, but overall not a bad job.
