OBD help
that would be OBD 1 for a 94 and even the 95. The OBD2 was 96 and up. My 95 has the OBD2 connector. Not sure if 94 does. What type of scanning tool are you using? I use my PC. Tons of info in scan and tune section here.
The 94 is ob1 but has a ob2 plug don't need a scanner just jump the connector with a paper clip and can read the codes off the dash you can find it on youtube and am sure it is in here someplace
I bought a MT2500 snapon scan tool for obd1 on ebay for less than 200 bucks..had a lot of cables, the books and the cartridges for my 84..It works great and has many functions.. much more than reading codes.. I just looked and there are plenty of them.with gm carts..most read 80s to 93 but most work on 94 ..
Craig
Craig
Craig
Craig
I always check the sellers feedback on ebay, it tells the tale.
Besides if you get shanked on ebay and used Paypal you will get your money back..
I use ebay to buy and sell.. never had a problem..
Craig
