Instrument cluster
Instrument cluster
Does anyone happen to have a gauge cluster for late c4 that they could take some detailed measurements from? I noticed that the 97-02 Camaro cluster is the same size, but I think it mounts slightly different.
I'm looking into changing the cluster because a while ago my speedometer started acting up, and since then I have noticed it only acts up when the interior gets hot. My guess is the CCM has some problem.
The clear plastic piece and black panel on the cluster would need to be kept from the C4 and modded to work, but other then that and possible mounting changes they are the same size. I have access to a Camaro cluster, but I don't have one I can measure for the C4. When I changed the light bulbs in the C4 cluster I quickly compared them, but not in enough detail to verify mounting locations etc.
