Rocker Panels - Glued or merely bolted on?
Are the Rocker Panels on a C4, glued like the C5 on... or are they merely bolted on. I have seen posts that there are tricks to removing the bolts but was not sure if the panel is also epoxied to the car.
Thanks in advance.
Thanks in advance.
10mm bolts/screws if I recall correctly. There is one each at the front wheel well and the rear also along with a few along the lower edge of the panel.
(TO INSTALL) seems to me, you need to install the rocker panel first WITHOUT the rear inner fender liner and without the bottom rear self tapping screw. then, you'll need to install that small self tapping screw from inside the wheel well opening. now install the rear inner fender liner and fit the bottom tab under the rear edge of the rocker panel. finally align the holes in the fender liner tab, and rocker panel and install the last, bottom, self tapping screw.
(TO REMOVE) reverse the above....
