1986 passenger headlight motor
hi, the right side headlight wont open when lights turned on, i have to push on the headlight manually all the way to open position, it closes on its own when the headlights are tuned off from dash , thought it was gears, i changed motor and gears with other ones i had still same problem, i have to physically push on it to open and it droops a bit when all the way up, any suggestions please and thanks
hi, the right side headlight wont open when lights turned on, if i push on the headlight then it opens,it closes when the headlight are tuned off , thought it was gears, i changed motor and gears with other ones i had still same problem, i have to physically push on it to open and it droops a bit when all the way up, any suggestions please and thanks
Junior Member
My Corvette Photos
Default 1986 passenger headlight motor
nikos1986 is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Old Today, 08:44 AM #2
gregs86
CF Member
gregs86's Avatar
My Corvette Photos
Mine was the brushes not making good enough contact just bent them in a little fixed it.
gregs86 is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Old Today, 09:22 AM #3
nikos1986
Junior Member
My Corvette Photos
Default headlight motor
Quote:
thanks where exactly is that, and did it help the drooping down a bit as i have thanks
Old Today, 10:36 AM #4
antfarmer2
CF Senior Member
My Corvette Photos
Quote:
Check the voltage at the plug to the motors. Its three wires; gound, up and down. This is controled by the head light relay.
If that it OK, then the cut off switch in the motor is bad. It works when the motor torques up and the armature is forced up or down. This opens a switch inside the motor housing.
