92 seat alternative
94 -96 seats are way more user friendly to those that are a little bigger . also there are some aftermarket sets that fit . but I forgot which ones they are . old age and a case of C.R.S.i guess
If the switch needs repair, it is located on the left-front of the seat. For some reason, the switch is prone to corrosion, if so, some maintenance is recommended. If the motors are faulty, that is a bigger problem. Yes, you can always replace the seats (4 bolts and electrical connections).
Either you don't fit well between the bolsters, or the bolster switch isn't working to allow maximum room.
Access switch wiring by removing the seat cushion.
Press down on wire in front of seat to release cushion.
If switch doesn't move bolsters, by-pass the switch by jumping the wires at the switch to confirm the motors are faulty.
