Removing Rear Bumper Cover
I'm having some paint work done on my 88 Coupe, and the rear bumper cover needs to come off. The body shop is telling me that they'll have to drop the gas tank and exhaust to get it off. Is this true?
Anyone out there have any real world experience that I didn't see posted?
One thing I noted of interest - the posting mentioned that if you only want it apart far enough to paint it, you don't even have to take the lights loose, just pull the cover off far enough to be able to do masking. Obviously, like everything else, it depends on whether you're looking for show car finish or not, I suppose.
64Scout (09-19-2022)
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
87YellowVette (04-06-2020)
Below are pictures 15 years ago when i changed the car to the 91-96 bumpers, as you can see the exhaust and gas tank is still there.
You can reach the bolts easilly, the top ones by removing the filler cover for easy access.
Having a Babe to help with slender arms and hands really helps.
As the saying goes.
Run forrest run.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
That's what they are telling you so they can add an upcharge... or they know nothing about a C4.
That is true. Most shops know nothing about a C-4. Why would they? Most shops have never worked on a C-4. Lets face the fact that our cars are older than most of the techs that do the work in most body shops.
It's not a fun job that I'd want to do every day, but it can be done.
I reached in through license plate area (remove spare tire retaining bracket gives you more room), removed the tail lights, then reached in and removed the nuts holding the bumper on.
If you do it yourself, make sure you wear a long sleeve shirt.
(I found the front bumper to be more of a P.I.A. to remove and replace than the rear.)
That said, it is very possible to remove the cover without dropping the tank, long arms help......
