just bought 88 vette, oil capacity
2nd Gear
So recently I purchased an 88 vette, I researched everywhere about oil capacity and ke getting fro. 4.5 to 5.5 QTS with filter....
I'm confused, how much do I fill??? With filter....
That should do it and of course you "stick it" afterwards to confirm. Since the car is new to you, the indicator should be part #'d 14094758 right on the indicator. Full after a change would confirm the pan hasn't been changed at some point.
The FSM will likely mention 4 without BUT it will have a note *check after to confirm.
