Flasher or switch
Flasher or switch
Hey-lo Yall,
Here is a head scratcher. Please can you help figure it out. I cant drive my car because It wont pass inspection.
I realize Chevys have two seperate flashers.
1. Harzards Flasher
2. Blinkers Flasher
Here is the deal...all hazard lights blink, Ok now the turn signals. The left side blinkers work front and back. The rightside blinkers dont blink the lights stay stay lite but no blinking.
could it be as simple as replacing the turn signal flasher ??
Incintive: To the solution post, I will send a $25 Darden Resturants gift card.
Max
1. Harzards Flasher
2. Blinkers Flasher
Max
If he replaces the flasher( a cheap part) It removes it from the possible problem.I just went thur turn signal hell not sure if it was blub or flasher,so on a 20 year old car I just replaced it all. problem solved
Same flasher operates both sides, so the flasher is good.
What the OP is describing is a classic sign of a bad bulb or bad connection on the right side.
GM cars for as long as I can remember operated like this.
If a bulb goes bad, you get the solid indicator on the dash and that side turn signals won't flash.
FLASHER OR SWITCH or BULB ??
If the socket or bulb are bad then why do the rightside hazard lights flash?
Arent the harzard lights and the blinker lights one- in-the-same seperated only by different flashers. ??
I replaced the rightside front cuz it was missing, so that one is new but I did not replace the rear right, yet. I will replace it and see what happens. Ill let you know.
Max
Hey KG'
Max
Max
I can only speculate that
1. the load/resistance of the emergency flashers is enough to make the flasher operate whereas the blinker system does not.
2. The emergency flashers and blinkers use different bulbs/filaments to operate.
3. GM designed the emergency flashers to operate in the worst case scenario. This means regardless of bulbs absent or non-functional.
Regardless of design and function, everything I have read concerning your issue points to a bad bulb, a missing bulb or a bad bulb socket. You can see that in the link I posted of the exact issue you are having by another forum member.
Are there possibly other missing bulbs?
I would compare the left side to the right side using the blinkers and not the emergency flashers. This might be the key to finding out what the problem is. Turn on the left blinker and walk around the car. Make note of what lights are flashing and who many there are. Then turn on the right blinker and make not of what lights are on and what may or may not be missing.
Do you know for sure you put the correct bulb in and that the bulb is making good contact?
Max
99.9% of all forum troubleshooting is guessing and speculation. Why? Because no one but the owner can actually touch the car.
For all we know you could have a very unique situation of rabid poltergeist squirrels that are storing their ghost nuts in your light bulbs.
Feel free to put a DVM, ohm meter or test light to work and read a schematic/tech manual.
With all due respect of course!
bulb
Hey-lo Yall,
1. Harzards Flasher
2. Blinkers Flasher
Max
1. Harzards Flasher
2. Blinkers Flasher
Max
If head lights and hazards are both on are all bulbs blinding? If not non blinking bulb is where to look. Poor connection, wrong or defective bulb, or socket issue. If all lights blink while head lights are on replace turn flasher with hazard flasher. If turn signal operates correctly. Get another hazard flasher. Flasher is basically a circuit breaker hazard flasher has a lower amperage to open. Turn flasher is more calibrated towards actual circuit demand that is why it won't open(flash) if bulb is out
Good luck
Good luck
turn signal bulbs are 2 element normally 1157 or 2057. A or NA on the end for amber bulb which goes with clear or white lens. 1056 or 1156 are single element bulbs that will cause turn signal not to flash
