84 engine swap to a l98?
Im new here and just got my first corvette a 84 with 74k miles. Found out i has a bad crank from a spun bearing. I just bought a 86 that's in need of some serious repairs but motor is good. Can i put the 86 motor in my 84 and what can i keep on it? I know i will have to switch the intake.
My first corvette 84
Needs some love to the interior
Pro Mechanic
The '86 long block (block, w/rotating assy, heads and valve train) should bolt right into your '84, and your '84 intake should bolt right on to the '86 long block.
i
Thats what I was wondering but could not find any one around here that could tell me. Thanks
I found out my 84 was born 11/83 and the 86 i got for a parts car was born 12/85
Pro Mechanic
If the build date is 12/85 then the '86 has cast iron heads.
All '86s have a one piece rear main seal.
I would put the whole '86 engine in with the TPI intake. Make sure you use the '86 ECM.
Pro Mechanic
