power antenna ground,
Would someone be willing to post a pic/description/and instructions for getting to and cleaning the ground by the power antenna on a 95 vert? Help, as always, would be much appreciated. I tried searching but couldn't get specifically what i needed...found for coupe but not for vert. Please and thanks in advance.
Its a start. I think that may have been one I looked at when I searched. Was hoping someone had some first hand knowledge and guidance. Thank you
There are two grounding points for the antenna as seen in the link provided. The braided strap will be at the antenna itself and go to the frame rail. The ground for the antenna "motor" should be found behind the seat in the RH storage compartment bulk-head. (G401). I don't know how much more information you could possibly require. I have never seen anything but a description of the G401 location on a C4 'vert and I expect it should be a very easy find. A ring terminal with a black wire behind the seat forward through the storage compartment.
If you're attempting to correct a "run" problem with the motor I doubt that the braided strap to the ground plane should be an issue but check. There are also 4 loose wires at the antenna ground plane that are 31+ inches long but connect to nothing by design.
Item #8 isn't stated to be G401 but I expect that it is. If you have a FSM check the 10-12-X (X being a page in that section)
Attachment 47888157
Attachment 47888163
Attachment 47888157
Attachment 47888163
