Replacing the Digital Temperature Coolant Sensor
Old 06-13-2015, 09:47 PM
reg_255
reg_255's Avatar
Default Replacing the Digital Temperature Coolant Sensor
Hi All,
When replacing the digital temperature coolant sensor on a 92 (the one in the water pump) do I need to drain the coolant?
I noticed the digital coolant temp does not raise past 142 degrees, also seeing a H15 code.
Thanks for the help you all provide.
Regards,
Roy
Old 06-13-2015, 10:18 PM
antfarmer2
antfarmer2's Avatar
Originally Posted by reg_255
Hi All,
Regards,
Roy
You need to drain some you don't want to get your opti wet a good time to flush it take both your knock senors out to do it right.
Quick Reply: Replacing the Digital Temperature Coolant Sensor
