Pics of tunnel behind plate
Next question is now that I have the foam cut out from the front, how the hell did you guys cut out the back piece. I see some have drilled holes but if I want to run a tunnel space is very tight for cutting. Also what did you use to cut with.
The piece you're looking at through the foam is actually a 3-sided U-channel that makes up a crossmember. I don't think it's a structural piece (some guys just cut it away) but, because I wasn't sure, I decided to drill it instead of cut it.
That piece would be much easier to deal with if you remove your hood and work from the top. I was working alone and didn't want to fool with trying to get my hood lined up again. If I had removed my hood, I would have drilled or cut the top of the crossmember instead of the front. This way the air would hit the back (inside) of the U-channel and been forced upward. But, because I drilled the front, I made a little air dam which runs from the holes, up to the air filter. I also drilled out the rivets in my air filter and turned the air horn around to catch the cool air from below (it normally points upward; mine now points downward).
The second pic shows the air horn turned around a a 3/4" spacer I used to increase the inlet (probably unnecessary but what the hay).
In window 25 is what mine looks like now. After looking at it and seeing how the air would flow with the hood closed it seems that cutting a hole in the bottom of the filter housing would be the way to get the cool air in better.
Why ruin your air filter housing? Just drill out the five little rivets and turn your air horn around so it's picking air up from below, instead of from above (Post #27). You can then either screw or pop-rivet the air horn back onto the housing.
Sorry did not mean the filter housing meant the shroud below it. Bty my housing and horn look diff from yours also I already had the air filter top cut off mod.
