1993 corvette mechanic
If you do not wrench on your cars and want a mechanic ask your local corvette club who they use. As mentioned you could save a lot by doing your own work. This forum has many knowledgeable people on it. Don't take it to a Chevrolet dealer .
They are cheap
Let me see if I can find the part number for the lt1 noid light
I.believe the part number is 25143
Connect the noid to fuel injector connector
See if lights up while the engine is cranking.
If it doesn't, opti is bad. Have you checked for spark at the coil?
Code 72- VSS signal circuit error. Check the VSS and circuit for short to ground or open circuit, a bare wire can cause an intermittent problem. Verify this first. Also check the VSS to make sure no excessive material has built up on the magnetic end, such material from the transmission wearing over a period of time cause deposit fine shavings on sensor head interfering with sensor operation. Wipe clean with paper (not cloth) towel to remove material and reinstall. A newly rebuilt transmission can deposit these quick enough as the transmission is "breaking in". If all else checks out, replace sensor.
Code 73- Pressure control solenoid. (1994-95). Check the pressure solenoid. Normal resistance is between 3-8 ohms at 20C (68F).Replace if out of range. Check lines for damage. Check for clogged filter and replace f necessary.
Code 74- Traction control system (1994-95 F & Y body). Low voltage indicated in traction control circuit. Check for shorted to ground or open circuit.
is this on a 93?
They are cheap
Sounds like a bad optisprk.
Convert to a vented setup or you could have the same problem again soon.
Also do some research on which model optisprk is a quality replacement. The oem is hard or impossible to find anymore.
I purchased a noid light kit. During cranking there is pulsing light. I checked only one injector.
They are cheap
