Headlamp
Headlamp
My basic question is can the isolation relay cause one headlamp to fail? One of my headlamps works, well the other does not. I tried swapping the relays which did not fix the problem. Now I am hoping it is the isolation relay. The motor doesn't seem to run at all on the passager side
The isolation relay is only used (through its normally closed contacts) to close the headlight. If the wiring is the same as my 84, both lights get power from fusible links to open the headlight doors..
Cliff, for this to work you need to disconnect the motor first or it will provide power to close the door. You would need to switch the light sw. on, turn the ****, then turn the light switch off. If the door closes then the motor and that part of the system is ok..
Isolation relay.
If I pulled my isolation relay and nothing seemed to Change does this point to a bad isolation relay? The one headlight continued to operate as normal
