Common oil leak places on 95 C4
I'm looking at a 95 C4 with 77k mile, it drops about 4 to 6 drops of oil on the ground overnight. Looks near the back of the motor, and can be smelled after driving to temp. When on the ground looking under the car the oil pan appears moist, not covered in driplets. I didn't see any clear sources, but hoped for common spots on this year model.
Please advise of any other areas of problem I should look over before purchase.
Thank You in advance.
BA
BA
Rear main?
Spray/ clean everything. Poof with baby powder. Guaranteed you'll find your leak.
vettespecial (06-03-2023)
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
You may also want to check the front and rear of the intake another very common area for oil leak on the LT1-LT4.
Pro Mechanic
BA
BA
St. Jude Donor '16
The LT1 intake is very easy to remove, Do a search many posts and how to's here.
St. Jude Donor '16
"Quote"
The LT1 series Gen II small block Chevrolet is very similar to the standard small block. They use similar internals, exhaust manifolds and oil pans. The main difference in the LT1 is the reverse cooling design, which cools the cylinder heads first, then the block. Because of this, there is no water that passes through the intake manifold. Coolant is transferred from head to head by a steam line on the back of heads. The thermostat is located on the water pump. Also, the water pump is cam-driven, rather than belt driven. In 1996, an LT4 was available in the Corvette. The LT4 had the same features as the LT1, but had larger valves, larger intake ports that were located higher, and an intake to match. The LT4 also came with a more aggressive cam to enhance the better heads.
Removing the intake is fairly simple. A lot of brackets to remove and you have to pull the injectors. If you do this, you might want to buy or borrow a fuel line disconnect tool. I got a set from Harbor Freight for $13. The gasket kit is only around $15, so the job is fairly inexpensive.
If you do this, remember there are 12 bolts on the intake and not 10. I lost 3 good hours out of my life learning this valuable lesson.
Another fairly common place for a leak is the oil pan gasket itself. If the leak is coming from the back, I find it very difficult, if not impossible to tell if it originates from the seal or from the oil pan.
If you're mechanically competent, it takes 90 minutes or a bit less to R&R an LT1 or LT4 intake.
Very easy to run a finger along the back edge of the intake manifold to check for leaks. It should be bone dry.
After you have disconnected the two fuel lines on the right side of the engine, what’s the safest way to cover the lines so you don’t have fumes escaping into the space you’re working in?
Thanks in advance.
B17Crew
Thanks in advance.
B17Crew
