1988 coupe for sale, Willits CA
Here for your consideration is a like new, low milage corvette (77,643) with the rare Z51 suspension and dealer swapped chrome turbine wheels. options as follows: 4+3 manual transmission, dual power leather seats, two tops,(glass targa and solid), engine oil cooler, heavy duty radiator , Z51 racing suspension, Delco Bilstein shocks, Bose stereo, rear window/side mirror defoggers. Torch red paint is bright and vibrant, with only a few very small chips most of which cannot be readily seen. Paint is a 9/10. Seats are near mint as well as the entire interior which is also a 9/10. everything works, it drives and handles like a new one. stock engine has lots of head snapping power with the 3.07 axle/manual trans. Suspension is tight! the original owner did a dealer swap and got the chrome turbine wheels which are super rare and make this '88 vette really pop! aftermarket wheels are all chrome and do not have the matte black paint inside the turbine slots as these do. It has a new stainless Flowmaster exhaust that adds horsepower and sounds ever so sweet with it's throaty rumble! the A/C blows ice cold. I had the rear window tinted to match the top and the look is incredible. It also keeps the car much cooler. Brand new Goodrich G-Force super sport tires have less than 700 miles on them! This classic is a real head turner. in all ways it is "like new" you will not have to immediately pour 5 to 10 thousand dollars into it to bring it up to pristine condition as you would with most cars that are over 27 years old. All maintenance records since new, clean car fax, no accidents, California smog compliant, clean title!
work done in the past 15,000 miles include:
new heater core; new brake master cylinder; 4 wheel alignment; 4 new tires; 4 new Bilstein shocks; new clutch master cylinder; new clutch slave cylinder; rear wheel bearings replaced; throttle body cleaned; new plugs, wires, cap, rotor and coil; rear U-joints replaced; all 3 catalytic converters replaced with new OEM units; new flow master exhaust/mufflers; overdrive-fluid & filter serviced, manual trans. drained, flushed and refilled; New ECM module; outer rubber window seals replaced; new rear brakes; new water pump, radiator hoses, and serpentine belt; new Lloyds mats, front and rear; new OEM console lid. new Pioneer hands free stereo with USB, 4 JL Audio speakers and Alpine amplifier. soft shield car My pictures did not load so please go into my profile and check out album/photos there are many to see......$13,500
Last edited by spartangreek; 08-02-2015 at 11:15 AM. Reason: pictures did not load
