newer C4
newer C4
When we last left Joe . He had installed a new cam shaft, timing chain, and roller rockers on his 1984 Crossfire 4 plus 3. Which he planned on driving to TN. And, it performed awesome. Even went up to the Dome. Great drive down 95 Shenandoah valley. One the return trip he noticed that the voltage regulator said 11 volts. He pulled into a motel 8 to either fix the problem or stay the night and buy a new alternator and continue home. The repair failed so off to sleep at 11 PM. Only to be awakened at 2 AM. Hello this is the front desk your car is on fire.
Yep it is gone.
So I have just purchased a 1989 6 speed with Z51 suspension package. Not running . It was parked in a garage eight years ago. Any advice? Thank you all.
Oh and the drivers side blue seat is NFG. So any suggestions regarding what manufacturer to buy a new seat cover or seat cover and foam from. Thank you.
Yep it is gone.
Yep it is gone.
Yep it is gone.
Good luck with the new car.
I am sorry to hear about your '84. I once had this same issue. I isolated it to a bad terminal block behind the battery. The block was deteriorating, which was causing the wires to loosen and arc. I am quite sure, now more so, that a fire was not far off. Whenever I read people complaining of unexplained voltage drops, I beg them to check this. Glad you were not hurt.
Any sugggestions with regards to the best place to buy seats. Oh and has anyone successfully dyed black seats to light blue.
Thanks again
Sorry it took so long to get back to you. Thank you about the car. It ran so good. Stupid thing the Alternator shorts out, jesus. Well I got the 89 hopefully I will have good luck with it.
Thanks again
Thanks again
But, if you need to replace the entire seat, Vette2Vette (also a sponsor) has provided me with some very nice seats too.
