100k club
118xxx on mine. Just finished rebuild, due to oil pan leaking and I had the cam gear off by one tooth when I installed the LT4 Hotcam a couple of years ago.
The rotating assembly was in great shape before, but I should be good to go up to 300K now.
118K crank and cylinders. Before, plenty of life left in it.
Exactly... love to see these cars still running strong after so many miles. They run better and last longer when they are driven regularly!
I've got 60,000 miles and drive about 6,500 per year. So, she will hit 100k around the year 2021. Many miles and many smiles to go... enjoying the journey getting there!
I did say I drive 6500 per year which is technically incorrect. The Corvette is not my only vehicle. DD is a 2006 Tacoma that sees about 12,000 miles per year. So my yearly total is over 18,000.[/QUOTE]
WOW that's some good mileage and she is still gorgeous!
What have you done to her over the course, other than belts brakes hoses tires and other wear parts? Opti & water pump? U-joints? Wheel bearings? Alternator? Very curious.
Thanks, Did the oil every 3k, I just rebuilt the headlite motors and did the ac control unit, Changed the rear oil and serviced trans at 150k, everything looked good, Ive always tried to do my own work on car,(Thanks Youtube).. It just started a small oil leak, maybe front seal?, Has original weatherstrip that still seals good...May do some seat covers soon..Its a driver that I still enjoy daily...Also really enjoying this site,This was my first post, lots of great people and info here!
#33
Currently under 100k, but two previous ones went past.
1988 A4 I sold at 115k. I put about 45k miles on it in about 2.5 years.(sold to get the '94 6M)
1994 6M I sold at 145k. I put about 50k miles on it in about 2.5 years. (sold to get a '95 6M)
Both were running great.
