Targa Top Repair
Targa Top Repair
Hey guys, I decided to try this stuff as a last resort before buying a new top:
http://www.eplastics.com/Plastic/ple...SIVE-IPS-4-4OZ
http://www.eplastics.com/pdf/IPS4SDS.pdf
From what I've read about it it should be able to fix the small crack in my top. It's relatively expensive at 10 dollars for 4 ounces but if it works it saves me $800. It's in the mail and I will let ya know how it works out.
Colton
Colton
Are the tops actually acrylic or some other kind of plastic? I would think acrylic would be too soft.
These glues work by dissolving the plastic and "melting" the edges together. If it's not the right kind of plastic it won't work.
and to the OP, im on an iphone and right below this thread apears my old thread if u r interested in reading about the things i tried.
I have a copy of the Motor Vehicle Manufacturers Association specifications for the '84 Corvette. This document lists the optional "Removable Plastic Roof Panel, RPO code CC3, as Acrylic Plastic, coated for scratch resistance". This spec says the optional roof is 4.4 lbs. (2 kg) lighter than the standard roof.
The glue claims to work for acrylic and polycarbonate. I believe it is technically Lexan as it says it on my top and from what I found lexan is a polycarbonate material.
No such markings on my roof panel. Is your top blue or bronze? Eckler's sells several tops, listed as either acrylic or polycarbonate. Could it be your top isn't an original GM top? Since your roof panel is marked Lexan, that's your answer, and it doesn't matter what my roof is made of! Good luck to you with the repair. Let us know how it comes out.
I've only owned my '84 for 12 years, so don't know if it's the original acrylic top, but it looks like new! I use Mother's Clay Bar.
