Seating the front of the pass door panel on the door...always seems loose up front
I noticed my 93's pass side door panel always seems loose on the front corner.
The door panel is in excellent shape.
Upon closer examination, it appears that part of the door gaskets cause the front of the door panel to sit high and not 'hang' over the lip of the front door.
Is trimming away some of the gaskets, such that the door panel can seat deeper into the lip/groove of, the way to fix this problem???
Does anyone have any ideas?
Am i correct here
Am i correct here
my 94 did the same thing but on the back I took the door panels off and drill two small holes in each a few inches from the front and back just under the rubber lip on the door sweep the put a two or so inch screw in each at a slight angle so they hook over the door frame look for the best spot works great and the screw is completly hidden
