Another ECM rebuild ? - - - current remanufacturers . . .
Who are the current known reliable remanufacturers?
A search only comes up with ages old info . . .
"Thanks"
"Thanks"
I pulled this one from a code 41 discussion that I was following.... It's from 2010 but hopefully still relevant.
http://0343881.netsolstores.com/index.aspx
I just emailed them to see if they could rebuild the 1992 ecm.
check posts 9 and 16 in this thread:
https://www.corvetteforum.com/forums...post1590972509
SIA Electronics can check it and fix if needed.
I also had code 41. Both of the serial data lines running from the ECM to the CCM checked out with no issue, so I pulled the trigger and sent the ECM out.
They found issues with soldering on the board itself. Haven't had a chance to put it back in but hopefully it is the fix.
https://www.corvetteforum.com/forums...-code-h41.html
It was around $160. Here's some more info:
http://m.ebay.com/itm/16159278-92-93-Chevrolet-Corvette-ECM-ECU-PCM-Repair-Return-OE-16159278-/221848016015?nav=SEARCH
Like I said, I haven't tried it out yet but overall my experience was positive.
