you guys know how this goes - so...
I started out by replacing the rear sway bar bushings on my 85, and here I am six months later -
valve job is complete. hopefully, the heads will go back on today -
1993C4LT1 (10-13-2015)
Yep...planning a cam / headers / intake etc. purchase for my '89 and afraid this is what will happen to me.
Received 6,943 Likes
2015 C2 of Year Finalist
Your only seven more bolts away from removing the engine to clean and repaint
Been there, done that....still doing that. Funny how changing a bad alternator turns a TPI 350 700R4 into a miniram 383 six speed Vette over the years. One hell of an alternator. Good luck to you.
I don't feel so bad now where one leaking injector become a month long project to replace a bunch of stuff "while I was there".
Yep, started off to replace a valve cover gasket and a month later it had turned into a ported intake, new heads, water pump and pulleys/balancer "while I was at it".
It is a disease.
It is a disease.
best disease in the world to have. as I tell my wife, ' you know where to find me and i'm not hanging out in a tt bar or doing drugs '. once in a while, as in now i'm in the middle of HER 96 lt4, I do things on her vehicles so that keeps her happy.
Those "while I'm at its"....
My current project started out just needing to change the throwout bearing, and replace my custom slave cylinder mount. A few months later the car is still not put back together, and now has a rebuilt rear differential with new gears, 6 new u-joints to install, new trans/diff fluid, and I'm sure more while I'm at it.
PS
While I'm at this would be a good time to replace a few rear suspension bushings.
PS
We have all been there. Mine started with changing the distributor on the stock engine and I somehow ended with a 383 crate engine. GM should make their directions on repairs more clear.
