SYS flashing new stereo
Old 10-21-2015, 11:43 AM
bow tie guy
bow tie guy's Avatar
Default SYS flashing new stereo
information regarding this in the audio FAQ is hard to research lots of old posts some missing URL's
Going to be installing a Double Din and I kept wondering why you'd need to install resistors to mimic load
instead of just putting a load on the circuit by using LED and LCD circuits
to illuminate and Dimm the new head unit
Found this after many hours of "search forums" see #13 by jerris
https://www.corvetteforum.com/forums...nstall-az.html
conclusion: when installing an aftermarket stereo get ground, power, switched and unswitched, and power antenna from plugs at CDM
either with or without a metra bypass harness and get illumination and dimmer from existing plugs/wires behind head unit to avoid the flashing sys message no resistors needed metra 70-1855 is for non bose CDM under glovebox
Old 10-22-2015, 12:33 AM
Whiteonrice
Whiteonrice's Avatar
Good luck give it a try hope it works for you. I installed a double din in my 96 a couple of years ago and got the SYS light I finally gave up and soldered the two resistors in and the problem quit. I really forget where they went or how I did it but it was annoying and something I did not want to do. Hope you don't have to.
Rick
Old 10-22-2015, 01:40 AM
bow tie guy
post # 8 from ynk1121 describes this scenario
hope this helps someone else
https://www.corvetteforum.com/forums...#ixzz3pGCGql6B
Old 10-22-2015, 01:52 AM
bow tie guy
[QUOTE=Whiteonrice;1590744653]Good luck give it a try hope it works
curious ............did you use the metra bypass harness
Old 10-22-2015, 11:08 PM
Whiteonrice
[QUOTE=bow tie guy;1590744838]
My car didn't have the Bose Gold so I didn't have to deal with the amps in the speakers etc. and I didn't need the metra harness. I just pulled new wires from the new speakers and wired those into the radio harness. I forget a lot of the details, that car was like a bad relationship and I was very happy when the new owner drove it away.
Rick
To SYS flashing new stereo
Quick Reply: SYS flashing new stereo
