My 85 Corvette build.
#41
Thanks. He is getting excited about the car. This is the next problem. I did search but didn't find anything.
http://s721.photobucket.com/user/yankeyspeed/media/85%20corvette/20160228_155211_zpsilgk8pya.mp4.html
#43
Maybe your headlight motor gears are stripped. Here's a link to Zip Corvette's article on how to disassemble the motor and make the repair and upgrade.
Maybe you can disassemble and see if it is the gears first.
http://www.corvettemagazine.com/tech...r-replacement/
#45
Yeah the light switch is on the dash. Yeah I agree the gears are slipping. But after inspection I think the gears look ok. I have some new gears. I can stick in. I am picturing gears that have no teeth left. Maybe that's part of the problem?
#46
I just want to say thanks for the good information on this site. I had an idle problem and I adjusted the throttle position sensor and the car calmed down.
Still have not got the headlight problem resolved. Sometimes you have to walk away before the solution presents itself.
#47
Many times I have walked away for a while from a project when I had a problem. A breather always seemed to let me calm down and look at from a fresh perspective. Sometimes it's a short breather and sometimes much, much longer. Last fall I was doing a few upgrades and changes to a motorcycle I owned. One involved a seat upgrade and I got pretty aggravated with it after trying to figure it out for a few days. I walked away and last week, out of the blue, I decided to work on it. Within an hour I came up with a different way of solving the problem I had and doing it. Since a warm front is coming through this week, I'll probably finish it tomorrow or the next day. If I hadn't taken the time away, I probably would have taken a sawzall to the seat and wrecked it.
#48
The car is back together. Still fighting with the headlight motor. But I went on a 50 mile drive and no problems.
I did start working on the passenger side door panel. More cracked plastic than I thought. I will pick up a few parts for it but I think I can get it.
#49
if the plastic isnt bisible and you need to suture it back together, you can always plastic weld it with a simple soldering pen.
have a look on youtube, i do it all the time to repair everything from motorcycle ferrings to luggage to my washing machines plastic control panel.
Originally Posted by Scott
Lumbert;1591910309
Lumbert;1591910309
#50
#54
#55
It's been awhile since my last post. I finally got my truck painted. I'm using that as practice for the corvette. I did get a new complete headlight assembly. It turns out that it's still doing the same thing . So I'm thinking the relay. .
#57
I was having some problems with the car running and it threw a code 43. I Checked the timing and it was way retarded. I adjusted it to 8 degrees advanced and wow what a change.
#59
timing is 6 deg btdc. but my 85 is at 9deg btdc and it increases the exhaust odour a bit, but also bumps the seat of the pants of o'meter.
also, i see you have uninstalled the smog pump. i am looking to buy the black brace piece that goes from the back of the smog pump to the intake manifold.
are you still using it and would u will be willing to part with it if not. thnx.
