My 85 Corvette build.
welcome and looking forward to the pics
Welcome to the forum. Good luck with your '85. Progress reports with pictures are always welcome.
I wished mine had that. I was going to ask the question. What parts from other c4 can I use on mine to upgrade? like the z 51 parts. I sure others have asked but I'm not sure what to look up for factory upgrades.
Larger sway bars, z51 shocks, power steering cooler line, 2 turn lock to lock quick steering rack, wheels might have been wider too can't remember anymore, also maybe brakes differ not sure anymore either.
Went down to Ohio and picked up a load of parts I need to convert to a 5 speed. That won't happen until next year. But and am hunting all the parts.
We were talking and , is it rare not to have cruise control?
http://auto.howstuffworks.com/1985-corvette1.htm
Yes, of 39K 85 coupes built approx. 38K had cruise.
Got more work done on the car. I installed the new power brake booster. I thought I had the head light fixed but now both side are not moving. Going to check the relays next. I did find out the P/O broke and sorta fixed the gas pedal mount. So I will try and make it more correct. I did find that the P/O pulled the fuse for the Interoir light because the power antenna seems to be stuck trying to move. I pretty sure the mast is gone. I will write that on the list.
