Early '84 Trim tag decifer
Heres the trim tag for my '84. I can decifer the VIN# exterior color code 40L/40U and interior 28I.Anybody know what the E 060 would be?
for some reason, your image is not showing up on my laptop. anyway, the 40L/40U is the paint code - upper/lower and in this case, white. the interior, 28 (I), signifies medium blue. "E" is for 1984. the "060" has me a bit puzzled - ??? there is another active thread that addresses early 84 trim tags,
https://www.corvetteforum.com/forums...-bay-84-a.html
but the "06" was stated as the 6th month, and as for the other "0" - well, that has me puzzled. what is the build date on the door jamb sticker? if WVZR-1 is on-line, maybe he can shed some light on the "060" identifier.
edit: just realized you are the OP of the other active thread....
I read it as 06C (SEE), line 1 E is '84, second line E is paint.
good call - for some reason the image is now showing up on my computer. with the "C" thing. compare with the "C" in Chevrolet. it's definitely not a "zero." so, "C" would be the third week in the 6th month, and the car should also have a (door jamb) build date of 06/83. everything falls into place. the OP's vin is 10059, and the other threads VIN is 9072 - a difference of 987 units - well within the 2 week production run numbers.
