anyone rebuilt their insturment panel?
Old 01-08-2016, 06:02 PM
ghoastrider1
ghoastrider1's Avatar
Default anyone rebuilt their insturment panel?
Ok, I have pulled the panel, have it inside all ready to work on. Going to order parts from bantee folks. Now, I was very careful taking out the screws for the cover. Same when I unscrewed the main unit BUT, those 4 little bitty screws went AWOL on me and with one, yes, just one, rolling somewhere in the steering shaft,wheel assy. Dang, now gonna have to pull the steering wheel off. Any hints as to working on the panel? Anyone know what sized those little bitty rat fink, born in hell, I hate you, screws are?
Old 01-08-2016, 06:46 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Try a magnet
Old 01-08-2016, 06:52 PM
mcguirjf
mcguirjf's Avatar
Default Just finished rebuilding mine
Batee has a series of YouTube videos that were extremely helpful in the entire process when I rebuilt mine. Here is a link to one of them.
Sorry to hear about the lost screw. I believe the four screws that hold the panel in the dash are all the same size. For install use ski wax to hold the fastener when reinstalling.
I used a 1/4 drive socket on an extension to remove my cluster. Didn't lose a bolt, but the socket fell down the center console. I was extremely lucky fishing with a magnetic wand and recovered the socket. In the future I'm taping the socket to the extension.
Old 01-08-2016, 08:42 PM
ghoastrider1
Originally Posted by JrRifleCoach
Try a magnet
already did the magner on a wand thing, no luck. Gonna get a stronger one tomorrow.
Old 01-08-2016, 09:07 PM
chevyman_ky
chevyman_ky's Avatar
can you get a vacuum hose to it to try to suck it out
Old 01-09-2016, 01:24 PM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
What fun! It always made me feel better after one of those incidents to take a big old wrench and whip it out the open garage door as far as it would go! I checked to see that none of the neighbors in my cul de sac were watching though.
Old 01-10-2016, 06:45 PM
gerardvg
gerardvg's Avatar
Hi
I have used the bate repair kits (they are on ebay for the common problems)
The board connector pin set was bad on my 85, a common problem.
It was pretty much the only problem I had over the last 20 years with my dash part from a blown lamp.
I also replaced the light sensor and new cool lamps at the same time, she looks great now and was an easy job.
If you know how to use a soldering iron, you can do it yourself its quite easy with the online videos batee has for the repairs.
Otherwise pay batee to repair your dash.
ghoastrider1 (01-10-2016)
Old 01-10-2016, 07:31 PM
starrman62
starrman62's Avatar
This may help you feel a bit better...I was doing a valve job on a car once and dropped one of the keeper sides, it fell right into an oil port that led to the bottom end of the engine...If I remember correctly it was a Saab and the oil pan gasket would take a week to get (this was back in the day), so I used a small magnet and fishing line...took me about 4 hours, but I finally pulled it out!
Good luck with your project.
Old 01-16-2016, 09:19 PM
Scott Lumbert
Scott Lumbert's Avatar
I just did mine on my 85. Not terrible. I put led lights in and new screen covers.
To anyone rebuilt their insturment panel?
Quick Reply: anyone rebuilt their insturment panel?
