86 wiring
86 wiring
the manual says the radio wiring has a 2 plug with yellow and orange. i cannot find it and someone has taken the pink white from ?i also have 2 pink and 2 gray wires for? not hot. please help. lost
Do you know if it had BASE or Bose when build? Is the SPID label in the console on the backside of the door? Does the VIN in the windshield or on the door match it?
RPO code that starts with Uxx with xx being another letter (M, N, Q, U or X) and a number, an exception would be U1F (Bose/CD) I believe.
What are you trying to install? A BASE OE radio, a DelcoBose or an after-market? There should have been 3 4-pin connectors that would have been populated differently for BASE or BOSE. Are the connectors missing and you've just got "blunt cut" wires?
In an OE install the PINK "triggers" the antenna relay when the radio is powered on (your after-market should mention how to accomplish this). The GRAY is for instrument panel "dimming" and again I believe the after-market should explain how to control this. If you've got power and speakers figured the pink and gray I've done for you I believe.
The multiple PINK is I believe because it likely had Bose and the PINK powered the Bose also when the radio was turned on. PINK/WHT would have been for the OE CLOCK and I'd think if your after-market has a clock the install should be documented also.
Determine which PINK triggers the antenna and I believe you should be done. Find the PINK/WHT in the vicinity and terminate in some fashion. If the antenna works putting B+ to a PINK should raise the antenna in an early car.
wiring
