Just bought my First Vette (with pics) Needs work
clean the leaves off by the wipers and make sure all three of the drains are clear to keep water out of the car. also clean the drain behind the fuel cap to keep water out of the gas!!!!!!!
Congrats! Looks like a solid starting point, sir. Good to have you here and thanks for sharing your new find with us.
Happy for you,
Lee
Happy for you,
Lee
edit: Firing order was correct, just the labels on the plug wires were wrong. Still no starty.
what about valve timing, when you want to install that distributor
I can walk you through it's super simple check your private message inbox for my number Don
spray some starting fluid into the airbox and call me in the morning
Wheels look fine are they a mold knock offs from china or what
I totally forgot about starting fluid, I'll try that next. I appreciate the offer to call, I'm not gonna be able to touch this car till Wednesday I have a long day today. If I get stuck I'll take you up on that for sure.
If you don't mind me asking, what did you pick this vette up for price wise? Seems like it could be a real diamond in the rough! Best of luck getting the issue figured out.
skyhawk50 (03-03-2016)
TheCorvetteBen
Thanks, I thought I bought it right. We'll find out soon enough id like to have it road worthy by March (get it running then brakes tires and other simple maintenance).
#33
The injector on the right is the GM original "Multitec Injector" not sure about the replacement on the left. You need to jump on "Pologreen's" offer! They are easy to change.
#34
seeyouinajif, have you seen the car run? The engine may have run with the distributor in this position. The distributor can be set into many positions, and as long as it is set up to fire the #1 plug with the #1 cyl @ about 6-8 deg. BTC. Before you pull the distributor, try bow tie guy's procedure to see if the timing might actually be correct! Clean the timing marks first. Some White-Out in the harmonic damper timing groove is a big help. Since the firing order is okay, I'm betting the timing is okay, too!
It's true that the distributor isn't in the "factory position", but some things are a "so what", if you're not a stickler for details! Some would say "that's being too ****"! The previous "mechanic" obviously wasn't much for detail!
#36
I know there are people who are more "****" or more of a perfectionist than others but there are some things on autos that are just right. So reorienting the distributor is the right thing to do even if it works the other ways. If he gets the FSM, he will do well to have everything in it's correct base line position so instructions regarding those components will make sense. As an example, the distributor cap would not be jammed against the intake if it is in the OEM position. The OP suggests he will be tracking the car. If so, he needs to have all his ducks in a row to avoid any issues when he is pushing the car hard. I agree that the offer for a cheap set of matched injectors is also the best route. Those on the engine look rough.
He got a killer deal on this car. So just because you spend $1500 doesn't mean it will cost $150 to get it to an OK state. I would feel wonderful if I had $1500 in mine. It would have loosened my purse strings quite a bit. If the OP gets it running reliably in under $2500, I'd be surprised. Track tires can get pricy.
Good luck,
WEK.
Good luck,
WEK.
#37
bow tie guy (02-04-2016)
#38
Hot Rod Roy there is no such thing as "Bad timing" (it's either correct or incorrect) Si No ? it's not **** and it's not "So what"
been doing this for 41 years, Do I know everything absolutely not, and
I learn something new everyday, even at my age.
But thanks for the pointers Roy. from now on when
I think about ****, you'll be the first thing the comes to mind
How about them bears
ps how the hell do you know where his valve timing is
if the previous owner dropped the distributor in in the wrong position the valve time is off in relation to ignition timing
that's why I suggested he put it on TDC #1 compression
reinstall and check firing order on the cap
#39
Been doing this for 41 years. Do I know everything absolutely not, and
ps How the hell do you know where his valve timing is? If the previous owner dropped the distributor in in the wrong position, the valve time is off in relation to ignition timing.
#40
Ha lets stay on topic here guys. I appreciate the all the help and suggestions. I'm in Florida so I can't work on it right now, I will update after I truly a few things.
I do want to get a set of injectors, somehow I got sniped on the ones previously mentioned so I'm looking for a good set if anyone has any leads
