1984 corvette VATS problem ECM problem
The car will turn over but not run. It is getting gas and good spark. I went to crank the car and it would not crank. I scanned the codes and it is showing a code 46 any ideas?
Start by cleaning the key or trying your other one wait 4 min between attempts.
Unless there's a "TYPO" in the thread title I doubt the "wait" or the "clean" will fix anything!! Thread title mentions "1984".
***I don't believe there's a 46 for '84 either but ............... maybe the "flashes" are a tough read OR what year is it really!!
Sorry missed the 84 saw the vats. But it gives you somethig to do. Why don't try to hep him instead of sniping me?
Pro Mechanic
2. "The car will turn over....it would not crank." -Which is it, here? Does the starter crank the engine or not?
3. How have you confirmed the basics; spark and fuel? B/c if it cranks, and has spark and fuel, it should start.
Need more info. More accurate info.
Spray starting fluid into the throttle body and then try to start it. That will tell you if the problem is in the ignition or fuel systems.
I'm assuming the car is NOT an '84, based on the info supplied...
