Targa top rattles in it
Maybe a member here can point me in the right direction, my 94 has a nasty rattle coming from inside the targa top, appears to be in the middle of it. Can a targa top be taken apart and repaired? Its the original that came on the car. I would appreciate any help on this. Thank you for your time and response.
thunder1951 (02-08-2016)
Take the top off and look for seperation then tighten up the mounting bolts. The put the top on loosely tighten all four bolts then tighten both back then the front.
thunder1951 (02-09-2016)
Another possibility: In the 93's, there are little plastic bushings the two rear bolts go through. They are part of the top.
They seem to wear and flatten out with time, possibly allowing the top to "rattle" around the bolt.
At least that's what i'm thinking on mine. I have seen the bushings sold separate from
any other hardware, too - but can't remember where, of course!
Good Luck!
Good Luck!
