no heat on 96 corvette
So the 96 corvette i have doesn't blow warm/hot air. It always blows cool/cold even when I set the temp to 90F. It also gives me a code "2". Where do I start to identify the problem here?
Any help is appreciated.
First find out what error code 2 means. On my antique C68 system it means that the internal temperature sensor is open (or bad connection or related problems). It might have changed in the intervening 10 years.
I just watched the ChrisFix C68 video and it shows code 2 as internal temperature sensor problem, so apparently things haven't changed after all.
Next thing to look at would be the movement of the temperature blend door. It should go to the extremes when you go from 60° to 90°.
