1985 C4 Wheel Fit
1985 C4 Wheel Fit
I just purchased a 1985 Corvette.
I am looking at purchasing 18x9.5 (all 4) chrome 5 stars wheels that say for C6. (Tire size 255/40/18).
The wheel manufacturer will not guarantee fit on 1985. They only say 1988+
I've heard discussions about using adapters. However, the tire shop advised against adapters for some reason. Are adapters safe for the car or change the ride?
Thank you!
Thank you!
Thank you!
Amazon.com: 18-inch Fits Chevrolet - Corvette C6 Aftermarket Wheels - Chrome 18x9.5 - Set of 4: Automotive
Thank you!
You need 1 inch adapters, they bolt on to your car and the wheels bolt on them. The actual difference in offset between the 84-87 is 38mm to 54mm on the 88-96 3/4 inch but the adapters are 1 inch.
I have been using them for close to 15 years now and have not given any problems, i also track my car so that is a good reliability test.
You can get the 88-96 style wheels with offset for 84-87 so you do not need adapters, but they are in 17 inch?
Link to direct fit 17 inch chrome wheels
http://www.parts123.com/corvettecent...50f&ukey=16150
Link to adapters
http://www.parts123.com/corvettecent...50f&ukey=10148
Link to 18 inch C7 wheels "with correct 84-87 offset" no adapter needed.
http://www.parts123.com/corvettecent...50f&ukey=48138
ADAPTERS are good....spacers no. I ran adapters on my 85 for years using the car on the 1/4 mile drag trace and autocross without issues.
With spacers you will often have to use LONGER studs. The longer studs may lead to failure.
Thank you for the responses!
I found a 2005 replica wheel that list the correct offset for 1984-1987. It is the only one that I can find.
http://customwheelsmarket.com/18ch20corewh3.html
