1995 Corvette LT1 Coolant Part Help
Seems like every time I fix something, something else breaks. Now that I have changed the valve cover gaskets, I have a coolant leak. It's coming from a small plastic valve located under the high coolant fill tank by the windshield. It's a small cylinder with an arrow pointing toward the tank, so I assume it's a check valve. I see one that looks like it listed at Eckler's that calls it a hot water control valve, but it's only a cylinder with a hose connected to both ends. Coolant is coming out around the end cap after a drive and then I shut the car shut off.
Does anyone have any idea where I can find one locally? Maybe Chevy dealer? I can't find anything on line for AutoZone, O'reilly's, Napa, or Advance Auto. I can post a picture later if needed. I have been page by page through the service manual coolant section and this part isn't listed. Thanks for any help.
Edit:
O'Reilly's can have one here by 11 am, so I'm good. In case someone searches for this, it's O'reilly's part number 74795 Climate control heater - in line restrictor $10.99
Edit:
In case we're not talking about the same item, here's a picture:
Received 6,943 Likes
2015 C2 of Year Finalist
I just replaced mine last year it's a heater check valve. I got mine at Rock auto for less then five bucks
Well, a follow up: The valve I got at O'Reilly's leaked worse than the one I took out. I didn't even have to start the car. I took it out an blew through it and air came out all around the seam. I took it back and bought one at Advance Auto and so far it is holding. Same part # and same price so it's probably made by the same company.
For what it's worth the one I bought was in a Delco box from the mid 90's and it was fine
