DMITTZ's Corvette Build
#281
Doing the build was quite fun for me in that I learned a lot about the car and got to improve my skills a bit. It was nice to share the build with the community on this forum.
Cheers
KYC4 (06-14-2016)
#283
Just wanted to add one final post to this thread, I have driven the Corvette a bit this week and raced at a (wet autocross) today and the car did great and is running perfectly, the repair to the clutch hydraulics is holding up so I think it is good.
Take care everyone!
-DMITTZ
Take care everyone!
-DMITTZ
#285
Thanks Graham, it was not raining when I first arrived, but I was in the third (of 3) runs groups so by that time the rain had started and it was getting really wet. I left the race early, so I could clean the car up for the Corvette show at Preston's tomorrow. Although after 3+ hours of cleaning (not done yet) I am not sure if I will take the car to the show if its raining...
#286
I've been trying to get three cars cleaned today.
I gave in and came inside....
I might get the interiors done tonight and only take two cars.
I'll be at the DUECK Richmond show.
Graham
Graham
#287
Hope to see you at the dueck show if the Preston's show tomorrow is rained out.
#289
That sounds great, I'm a pancake fan, see you then.
-David.
-David.
#290
Do you know the part number for these or where did you get them? I have been looking for 2 days. I finally ordered 2 but they were the wrong thing. Rear knuckle seals.
#291
Here's a link to the part:
http://www.parts123.com/corvettecent...50f&ukey=23070
The teflon washers that go between the wheel bearing and the axel stub I got from my local dealership, but I think corvette central sells them also. I can try to find the part number of the teflon washers if you would like?
Hope that helps...
-DMITTZ
Robert61 (12-29-2016)
#292
I still have the washers. I threw the old seals away thinking they would be easy to find. So much for that. Thanks for the reply.
#293
Originally I was just going to reuse my rear spring bolts but I decided I wanted more ride height adjustability. I did not want to pay for one of the kits because it was too much $$$ for a couple bolts.
After searching online I found a Canadian wholesaler who sold Class 10 280mm (11.2inches) M20 bolts for around $6 each, so I picked up a couple of them and some grade 8 lock nuts and made my own lowering kit for about $15 CAD/ $12USD.
With these bolts I can go from stock ride height all the way down to basically on the bump stops with just turning the lock nuts up or down
I wish I could find the same deal on bolts that you did!! Distributors down here are a bit more proud of the metric stuff than $6 ea.
Will you still be able to get it back up to stock with the bolt only being threaded up a few inches? Looks like it would still put you lower than stock?
#296
I am loving this thread. This makes me want to go upgrade everything on mine!!
To answer your question about ride height, the new bolts have a longer threaded area than then the old bolts did. I can get to about 1/2in of stock ride height with this setup when i measured it. However I ended up with about 2-2.5in drop for my final height. That seemed to be as low as I could go and still have a decent amount of suspension travel. Lower would look better but then I was bottoming out on bumpy roads.
#297
Great Build
spent some time today reading every bit of your build and perfect is the only word i can think to say.
loved every moment of it and the pictures and info are great.
Thanks for your time and sharing all the fun and learning you did.
#298
It was a fun, project and I learned a lot. It has been nice to get to share it with my fellow enthusiasts.
#299
Jan 2017 Update
Since this thread has been getting some interest lately, I thought I would give a small update. I drove the car this summer and put about 2,500km on it, did several auto-x, one road trip and several cruises, I only made it to one car show though, hope to do more in the future.
The car drove awesome and it was fun. However, by the end of the summer I started getting the itch to work on it again.
I have started another thread to document the work I have done since. Here is the link:
https://www.corvetteforum.com/forums...d-vol-2-a.html
My second build, is a lot smaller in scope than this one but I am getting to do a few things I didn't get a chance to take care of in this build such as a brake upgrade.
Thanks again everyone for all the support on this build it has been fun
#300
David, if you're done modding yours, you can start on mine anytime!
This blog has been fantastic and I love the fact that you wrench on your car yourself!
Well done; your car rocks!
