94 fuel pressure question
Key on engine off fuel psi goes to 44 then quickly goes down. If I turn the fuel pump back on then clamp the fuel, line it still drops. Same with the return line. The fsm states it should then be a leaking injector. Raise the rail, turn the key, no leaks. Vacuum line on the fpr is fuel free.
Any ideas?
Any ideas?
Your pulsater is leaking or someone put the wrong hose in it's place. Pull the pump and see it is just on top of the pump.
Then the psi would have stopped dropping when I clamped one of the lines right? Anyway no pulsator (fuel line in its place), pretty new walbro pump and afpr.
If you used regular fuel line it is a mushy mess.
Fuel line came with the pump. I turned the key then went and clamped the fuel line with locking pliers. Does it have to be clamped right when the key is turned?
When you turn the key on with out starting the pump will run for 2 seconds how fast are you? Some pumps do not hold pressure like the factory did. Is it running good or are you just looking for problems?
Just tried that. Psi spiked. I couldn't get the clamp off fast enough. Everything in the fsm points to injectors but I don't see them leaking.
Fuel trims are in the 140's and I get a pretty strong gas smell after a drive. Figured I would check the pressure, thinking it might be a bit low. I was surprised to see it wasn't holding. It did last year when I replaced everything but the injectors.
Its worth mentioning that winter blend fuel will cause higher than expected fuel trim numbers ....
Last edited by PatternDayTrader; 03-18-2016 at 11:21 AM. Reason: Added winter blend fuel comment
Tail pipes look ok. O2's are new and working. I figured the ECM was adding fuel because the pressure was maybe low. Can't figure out why it's not holding.
