Can't find my interior fuse box?!?
7th Gear
I was hoping I wouldn't have to do this, but I'll be darned if I can find the interior fuse box in my '93 coupe. Owners Manual says to the right of the instrument panel, and I've look all over the place. Is it possible it's in the engine compartment. Thanks, and please be gentle with me. I've only had the car since yesterday.
ladman (03-20-2016)
7th Gear
Aha, found it thanks. If my cruise control isn't working, could it possibly be a fuse? I won't be able to check the fuse box until tomorrow. Thanks.
That would do it, but there are other things. Mine didn't work when I bought it and the two vacuum lines plugging into it by the battery were eaten by battery acid (apparently). The were mushy and cracked. I cut them back to where they were good and replaced the end pieces and every thing worked. According to the owner's manual, it controls other things as well:
Cruise Control Engage Switch; Daytime Running
Lamps Module; Low Tire Pressure Warning
Module; Cruise Control Cut-Off Relay
ladman (03-20-2016)
**I recall you maybe having a '95 so with a Lt1 in '95 a 10A with an LT5 a 5A like I would have expected in the '93.
ladman (03-21-2016)
What year is that "fuse-block"? I thought cruise should be 5A and this is what I would have expected in a '93
Attachment 47965042
Attachment 47965042
OP - here's some vacuum information for a '93. I had the FSM open and it was just a couple snapshots:
ladman (03-21-2016)
Using the pictures WVZR-1 has provided, here is where my vacuum hoses had holes. That's the battery just below.
ladman (03-21-2016)
