First used Corvette. No clue where to start!
This is my 7th Corvette, but the first time I bought a used one. I had a new C4 in 88, new C5's in 98, 01, 03, a Z06 in 04, and my last one was in 08. So here I am in 2016, and a friend sold me an 84 C4 for $1,500. A gear is slipping and the dash seems to shut off at annoying times, but I figured $1.5K is $1.5K and how can I pass it up?
Where do I start? Where do I check the frame to see if I have a good starter project car? The engine has 225,000 miles on it - where do I get a reasonably priced crate motor from? Tranny slips in 3rd gear - who sells a decent transmission (I didn't see one on B&M for 84). Do people keep stock dashes, or are there new replacement dashes? Do I need to replace the electronics?
Anyone that has done a restoration of an old Corvette - if you could point a total newbie in the right direction I would appreciate it!
I look at the car and just feel overwhelmed. So much to do and no idea where the beginning of the trek is.
Start somewhere, it all has to get done eventually, take a look at my thread "1800 dollar corvette build" might make you feel good about your purchase! Haha, stay determined, don't dump a ton of money into the car (Brand new engine and transmission) Dash can be sent to Bryan at Batee.com he did mine, amazing guy to work with. Why do you need a new crate motor? what's wrong with the current one besides high miles? Get the car on the road and drive it and slowly work on it, will definately keep you motivated, I haven't driven my car since purchase in october, because of the dry rotted tires, we want to see pictures as well! If you're not in love with the car don't waste the money, also another really good thread is DMITTZ thread on his car, amazing attention to detail.
Have purchased several TCI transmissions & recommend them. They have several builds dependent on HP + they ship in a nice hard shell case that makes a good dog house.
http://www.tciauto.com/tc/transmissionshtml
jay1055 (04-28-2016)
I agree with ghost, make sure it goes and stops first. Then in Florida the next most important thing is the A/C but you may be able to live without it.
Congrats on the addition, pretty much any information you'll need is right here.
Rick
Rick
Idk if there's a way to inspect the frame as a whole and declare it "good," but with the age and miles, you may want to consider fresh bushings throughout the suspension. The throttle plate shafts may need to be reamed for adding bushings, if loose. If the radiator is original, the plastic end tanks tend to crack. Bearings, seals, ball joints and u-joints may be failing, so listen for any odd noises & look for drips and fluids where they shouldn't be.
All plastic will be brittle, so be gentle! Rubber vacuum, fuel, brake, and coolant hoses may all be near the end of their lifespans, so inspect them as closely as possible. Any that look swollen & wet, or dry & cracked need to go. Also check the condition of the spark plugs, and examine the distributor for any corrosion. Mist the plug wires with a spray bottle at night & look for arcing.
Note the condition of all fluids, replacing anything questionable. A full coolant block flush through the knock sensor & drain plug is never a bad idea. I second using Batee.com for your dash troubles, either as a send-off repair or DIY; they provide excellent instructions. Can't help you on a new trans myself but others here have experience with those suppliers. Nothing else coming to mind right now that hasn't already been said, but I'm sure more will chime in with whatever I missed.
Post back with anything that you're unsure of, or any specific problems...and PICS ...and welcome to the C4um!
Dash conversion to analog gauges is an option.
http://vettaid.com/ReplacementGauges...ePackages.aspx
After the "whoa and go" then rent a power washer and degrease the engine and engine compartment (protect the alternator and throttle bodies with foil). Then do a plugs/wires/distributor cap and rotor. Set the timing.
Then flush the brake system, cooling system and refill the power steering with Lucas fluid. Clean out the tank and replace the fuel sock on the pump, blow out the lines and install a new fuel filter. Drain and fill the rear end.
Replace any questionable rubber/plastic hoses - especially brake hoses.
Try www.vette2vette for a guaranteed used transmission or any used parts.
Then prioritize any problems with the car and fix them one at a time.
I actually like the 84-87 wheels when they are cleaned up:
OP, good on you for taking the plunge! Everyone is a noob at one time, it's just some of us started at 14 or earlier to turn wrenches on cars. Plenty of mistakes were made, mostly by going too fast or not knowing exactly what we were doing. So my advice is take your time and search this forum, study other's projects and problems and their efforts and solutions. You CAN DO IT!!!
I suggest you read brandensbeast's entire thread. He's doing a great job and should inspire you to start your effort.
Also take ghoastrider1's suggestion to heart and start with the run, drive and stop stuff first. I understand that your trans is slipping so a rebuild at a minimum is in order. Ask around with friends or at a car show for a reputable trans shop and get an estimate on a complete rebuild, then compare to a new trans like TCI. You'll then know which way you want to go on the trans.
Go to batee's site like branden suggested and study up on your dash and see if you want to DIY it. Many have fixed theirs on their own, but a professional rebuild on these 'atari' dashes is not a bad option either.
Once you start seeing some progress it will feel better. When you hit a rough spot, just walk away for awhile and give it a rest. You'll get motivated again soon enough.
When you have a specific problem/question just ask, many here will help. Now get going and rock on.
On the dash rebuild... I have wrenched on cars since 1964, I was 14. I can rebuild most anything that makes the car go or stop. NOW, about that dash. I bought a $300 dash rebuild kit for my 86. Bought the tools I need for that job. When I reinstalled the dash, I got squat! Somewhere, or maybe two or three somewheres I screwed up. I ended up sending the entire unit to Baate for him to repairs my screw ups. He did a great Job. For the first time since I have owned the car, everything works.
About that tranny. They are prone to have a front pump seal leak. Pulling the tranny is a PIA. Not hard, just a pain. Have fun, enjoy the drive, who cares if the parts are worth more than the car.
