Long Bolts
Old 04-30-2016, 03:03 PM
Mishawaka
Mishawaka's Avatar
Default Long Bolts
For some reason I'm having a difficult time finding a cheap source for 12" bolts for the rear leaf. Anyone know of a source? Yes, I'm too cheap to buy a kit, don't plan to lower the front end.
Old 04-30-2016, 03:18 PM
Churchkey
Churchkey's Avatar
Cheap? IDK. I purchased grade 8 from Mcmastercarr.com
Mishawaka (04-30-2016)
Old 04-30-2016, 03:24 PM
Mishawaka
Mishawaka's Avatar
Did you use 1/2"? I'm trying to find 9/16", I heard that is what I should use.
Old 04-30-2016, 03:56 PM
Mishawaka
Mishawaka's Avatar
Found some 9/16" threaded rod there. Perfect, I will cut in half and tig weld some bolts on one end.
Old 04-30-2016, 04:57 PM
c4cruiser
c4cruiser's Avatar
Is there a Fastenal store near you?? They will have the bolts you need. Use Nylock nuts or similar as replacement bolts will not have a hole thru them for a cotter pin for a castle nut.
Also try Lowe's or Home Depot too. They will have bolts in the size you want but make sure to get SAE Grade 8 or Metric 10.9!! DO NOT use threaded rod unless you can verify the strength.
Old 04-30-2016, 05:36 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Any hardware house will have them. Fastenal, Bowman, Lawson Products, etc. Also Mc Master Carr (as mentioned), Grainger, or any local nut/bolt specialty shop. In fact, http://www.google.com/search?hl=en&source=hp&biw=&bih=&q=Mishawaka+Indiana+nut+and+bolt&gbv=2&oq=Mishawaka+Indiana+nut+and+bolt&gs_l=heirloom-hp.3...1684.9077.0.9257.14.6.0.8.0.0.105.377.3j1.4.0....0...1ac.2j1.34.heirloom-hp..11.3.272.-yXvpzaiNX8
MID STATES BOLT & SCREW
1755 Mayflower Rd
Use Nylock nuts or similar as replacement bolts will not have a hole thru them for a cotter pin for a castle nut....make sure to get SAE Grade 8 or Metric 10.9!! DO NOT use threaded rod unless you can verify the strength.
Listen to this guy.
Old 04-30-2016, 06:23 PM
Churchkey
Churchkey's Avatar
Used 5/8" NC.
Old 04-30-2016, 08:19 PM
chadk
chadk's Avatar
picked mine up at Fastenal
Old 05-01-2016, 03:31 PM
maj75
maj75's Avatar
I spent my first 27 years in Mishawaka. Mom still lives there.
Man, I don't miss the cold.
Old 05-03-2016, 08:49 PM
DMITTZ
DMITTZ's Avatar
Bought 11.2inch M14 Grade 10.9 bolts from Fastenal. I can lower my car all the way down to the bump stops with these bolts if I wanted to so you won't need anything longer.
To Long Bolts
Quick Reply: Long Bolts
